Quick Drop Enthusiasts
Quick Drop Plugin: Reset Origin
Note: This shortcut ships with LabVIEW 2018 and later with a default assignment of Ctrl-O. You only need to download it from here if you are using LabVIEW 2017 or previous.
Resets the origin for all panes or the block diagram.
Default Shortcut - O
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
Message 1 of 8
(17,009 Views)
Looks very useful, I find my origins drifting occasionally and this could save me lots of swearing
One question if I may: If I have a Front Panel with a number of splitter bars, in which pane will this reset the origin? All of them? Or can it determine the 'selected' or 'last edited' pane?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 2 of 8
(11,480 Views)
So far it resets all of them
Andreas Stark
Message 3 of 8
(11,480 Views)
Andreas, great work.  I updated it to also include the block diagram.  I hope you don't mind, but I thought others would like that feature as well.
Message 4 of 8
(11,480 Views)
Hey David,
it's even better now! Thanks.
Andreas Stark
Message 5 of 8
(11,480 Views)
Andreas, thank you for the helpful plugin! I modified it a little so that holding Shift causes it to invoke the OpenG "Fit VI window to content" function, as I find that useful.
____
Ryan R.
R&D
Message 6 of 8
(11,480 Views)
Did you update the download version of this?
Andreas Stark
Message 7 of 8
(11,480 Views)
Hey all,
I made an update to this QD plugin, it now reads each origin position and will not perform the "Set" if the origin is already at (0, 0). Moreover, if all origins are already at (0, 0), it will fail the transaction at the end, leaving no dirty dot if nothing has changed. Technically speaking, I made it from scratch before seeing this post, so there might be very small cosmetic BD differences. Anyway, enjoy 😁
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 8 of 8
(6,521 Views)
