Quick Drop Enthusiasts
TortoiseGit Show Log - QuickDrop Shortcut
This is one for any TortoiseGit Users out there.
This QuickDrop Shortcut launches the TortoiseGit log for a VI, folder, library, repo, class, library or project. If you set up LVCompare as your TortoiseGit diff tool, the log is a handy way of selecting 1 or more log entries to diff. It saves having to come out of LabVIEW and find the file in Windows Explorer and navigating the huge TortoiseGit menu!
Required Software:
  • Git (tested with version 2.35.3.windows.1 64-bit)
  • TortoiseGit (tested with version 2.13.0.1 64-bit)
Usage:
  • Ctrl+Space, Ctrl+G will bring up the log for the current VI/control
  • Ctrl+Space, Ctrl+Shift+G will bring up the log for the folder containing the current VI/control
  • Ctrl+Space, <Text in QuickDrop window>, Ctrl+Shift+G exposes additional options for which log entries to show:
    • <nothing>, file = this VI
    • folder, f, <shift modifier> = folder of VI on disk
    • repo, r = repo containing VI
    • class, c = folder of class containing VI
    • library, l = folder of library containing VI
    • project, p = folder of project of VI
Default Shortcut - [G]
Demo:
Here's a demo of me using the shortcut to bring up the log for a file and do a diff with the working tree using LVCompare.
Links:
  • Repo
  • Plugin to install: Available on VIPM  for LabVIEW 2018 and later (link added 23/08/22)
  • For those who need an earlier version, I've also attached a zip backsaved for 2015 which you can extract to your <LabVIEW 20xx>\resource\dialog\QuickDrop\plugins or <LabVIEW Data>\Quick Drop Plugins
Message 1 of 8
(6,771 Views)
I'll definitely be checking this out! Any interest in getting this on VIPM?
Message 2 of 8
(6,737 Views)
This looks quite helpful! I've been using my modified (aka bugfixed) version of https://bitbucket.org/jed_d/lv_tortoisegit/ Project Provider to add TortoiseGit functionality to the Project window. But it does require extra navigation that this new QuickDrop shortcut won't.
Message 3 of 8
(6,726 Views)
Thanks Derrick. I'd love to put it on VIPM - submitted it today.
Message 4 of 8
(6,719 Views)
I wasn't aware of this - thank you for alerting me to it! Just installed it and it looks great.
Message 5 of 8
(6,714 Views)
Here's my fixed version (the original developer has moved on from LabVIEW; my version just incorporates a couple changes I needed to get it to work properly on the LV version I was on at the time). I believe my newest .vip 0.8.2.2 was compiled for LV 2019.
https://bitbucket.org/tctautomation/lv_tortoisegit
https://bitbucket.org/tctautomation/lv_tortoisegit/downloads/lv_tortoisegit-0.8.2.2.vip
Message 6 of 8
(6,693 Views)
Hi Leah,
I installed it using VIPM. It works great. Super useful, I think I'll use it often. Thanks!
Message 7 of 8
(6,558 Views)
@Petru_Tarabuta wrote:
Hi Leah,
Thank you Petru! You're welcome - hope you find it useful.
Message 8 of 8
(6,550 Views)
