Quick Drop Enthusiasts
QuickDrop doesn't appear because the window is off the screen.
Since this was the first Google result I found when looking into this problem, just want to confirm that the F3 shortcut does work on LabVIEW 2016.
Message 11 of 12
(938 Views)
macOS
2023 Q3 on arm64 M2 MacBookPro
Three (3) monitors arranged (L->R): MBP Screen -- HPZ30i -- HPZ30i
(fn) F3 works as expected, centering the Quick Drop Window on the middle display.
As it initialized to the bottom of the rightmost screen and my configurations change, F3 really helps without needing to adjust the init.
Thank you.
Message 12 of 12
(508 Views)
