Quick Drop Enthusiasts
Show VI in Windows Explorer
This simple Quick Drop shortcut will find the location of a VI on disk, open a new Windows Explorer window at that folder location, and highlight the VI.  If the file is not saved to disk, a popup will warn you of this.
To install this simply copy the VI to the <LabVIEW>\resource\dialog\QuickDrop\plugins directory.
To run it, press Ctrl-Space and then Ctrl-F.
To modify the key combination, press Ctrl-Space, click "Shortcuts..." and then navigate to the "Ctrl-key shortcuts" tab.
For more useful Quick Drop plugins, see the Quick Drop Enthusiasts community group.
Message 1 of 9
(16,501 Views)
Will use this regularly.  Thanks!
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 2 of 9
(10,612 Views)
The tag says LB2010, but this VI is for LabView2011, please can you put a LabVIEW 2010 version here for the unfortunate few who have not updated yet please? Many thanks!
Message 3 of 9
(10,612 Views)
You got it, sorry about that.  2010 version is now attached...
Message 4 of 9
(10,613 Views)
I have installed this plugin as specified above, but it does not show up in the "Ctrl-Key Shortcuts" window, could there be something I am doing wrong?
Many thanks, Alec
Message 5 of 9
(10,613 Views)
The vi's path is:
C:\Program Files\National Instruments\LabVIEW 2010\resource\dialog\QuickDrop\plugins\Show VI in Folder.vi
Message 6 of 9
(10,613 Views)
Did you copy the 2010 version?  I see it just fine in the Ctrl-Key Shortcuts tab in my LabVIEW 2010:
Message 7 of 9
(10,613 Views)
Nice feature.
The following snippet add feature to show selected subVI in the Windows Explorer when shift is TRUE.
George Zou
Message 8 of 9
(10,613 Views)
I modified this too.  I updated the search so that if a file isn't in a folder, it keeps going up until it is in a folder.  This can happen when you try to open explorer to a VI in a LLB.  My method will keep going up then open explorer to the folder the LLB is in, and then select it.
I also modified it so that if you hold Shift the path to the VI is copied to the clipboard.
Message 9 of 9
(10,613 Views)
