RF Measurement Devices
5450 Test Panel error
I am trying to execute a vi using PXIe 1065 with NI 5673 RFSG and NI 5663 RFSA. When I try to test NI 5450, using MAX, it passes self test but upon clicking the Test Panel and running it using start, the sine wave isn't running and I donot get an amber light on the device's LED? Also after some time i get the timeout error!
Please help.
prads
(7,789 Views)
Hi Prads,
First, make sure you have configured the PXIe-5611 Properties page, setting the PXI-5652 as the LO source and the PXIe-5450 as the baseband arb.
Next, make sure there is a cable running from the PXI-5652 REF IN/OUT to the PXIe-5450 CLK IN, assuming you are not trying to lock the PXIe-5673 to an external 10 MHz reference.
Also try running self teston each of the three individual modules, and try Test Panels on the PXI-5652 and PXIe-5450 individually to see what happens.
Let us know what you find. Also, if you can post a screenshot of the error if you are still receiving one that would help.
Andy Hinde, MBA
Systems Engineering - RF
(7,787 Views)
Hi Prads,
Andy’s suggestions are the exactly what you need to follow. Are you trying to troubleshoot each part of the PXIe-5673? Or are you just trying to get started?
Jaime Hoffiz
Product Expert
(7,760 Views)
i think u need to restart ur hardware and PC!!!
I am sure it would work then.......
enjoy
Arpi
(7,755 Views)
I don't believe cycling the PXI chassis / PXIe-5450 power will resolve this issue.
Andy Hinde
RF Systems Engineer
(7,749 Views)
