RF Measurement Devices
Showing results forย
Search instead forย
Did you mean:ย
BT Connect Error Code: 6
Hello
I want to send physiological data via Bluetooth headset to my Pocket PC with headset compatibility. When I connect these two devices, the PDA detects the headset using LabView BT VIs. However, there is no activity going on the waveform chart. Once I stop the application, I get BT Connect Error: 6. Can you tell me what that error signifies and provide me with suggestions to go about eliminating it.
Thank you
Priyanka
(7,190 Views)
Hello pri,
I see that this question has remained unanswered for a long time.
Is this issue still open or was it handled in a parallel post?
Most likely this issue has already expired.
If yes, then just let me know, so that I can try to help you further.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. ๐Ÿ˜‰
(5,542 Views)
