RF Measurement Devices
ni5640 input data format
Hi:
I am new on Labview FPGA. I am using ni5640r.
1. I want to transfer an array of data which is generated by labview from host to fgpa by using Invoke mehtod (write), do I need to set up I and Q before I transfer it and which format am I using U32, U16 or I16?
2. In FPGA, when I read the data from host and send it to FPGA I/O node , do I need to convert it to 14 bit?
Austin
(6,281 Views)
Hello ni5640,
I see that this question has remained unanswered for a long time.
Is this issue still open?
If yes, then just let me know, so that I can try to help you further.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,535 Views)
