I need to do acquisition during 24h for signal antenna (with 433Mhz and
bandwith is 2Mhz)with PXI with Labview.
Each 1ms the data are acquired,
That data is filtered,
Then the power rms is calculated,
Then downsampling,(because the pxi sample at 64Msample/s, I need to
downsample for have less sampling),
And then stored in the file.
But I am a newuser in Labview, I have already look at example online
but I have not saw the example which can help me. I work with Labview
7.1 and PXI 1044(with NI PXI-5600 and NI PXI-5620).
I need your help.
Thank you very much
NB: Vous pouvez me repondre aussi en francais. Merci d avance
