RF Measurement Devices
FFT for USRP2
I am using the USRP2 with LabView 2010. It has a VI which does a continuous FFT from the USRP2. I want to know if I can connect multiple USRP2 to the same system through a ethernet switch and run the FFT program for all the USRP2 at the same time on the same system.
(5,578 Views)
Hello Vivek,
I see that this question has remained unanswered for quite some time. (I'm on a hunt to answer all previously unanswered posts 😉 )
I suspect that this question is no longer active.
If you still have some questions related to this, then please don't hesitate to let us know.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,421 Views)
