RF Measurement Devices
Packet Loss test
Hello all,
A bit of a newbie here. I am trying to use Labview to run a Packet Loss/ Throughput test for TCP/IP. I am testing a bridged wireless network overnight and want to determine the amount of packet loss and the average "Throughput" rate. There is a simple DOS-type program called NetIO, but it is not very informative and it does not give you any datalogging capabilities.
My setup for this test is like so:
Two Wireless AP's acting as Bridges with clients associated to each AP. I would like to determine the packet loss and throughput between the two clients during the duration of this test.
Has anybody had any experience with this(or something similar) with Labview? Any help would be great.
BF
(8,639 Views)
Hello BF,
I see that this question has remained unanswered for quite some time.
I suspect that this question is no longer open.
Also this does not seem to be the right place/category to post this question.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,789 Views)
