10-22-2010 02:43 PM - edited 10-22-2010 02:50 PM
Hello everybody,
After installing the NI-RFSA 2.3.1 drive and the Spectral Measurements Toolkit, I get the following message when I try to run examples for the downconverter PXI 5600:
"Error loading "niRFSA.dll". A dynamic link library (DLL) initialization routine failed."
Our system consists of the following:
Host
windows pc
Labview 8.6.1
We also have the Modulation Toolkit and FPGA Toolkit installed.
All software was installed in the order required in the manuals.
Target
PXI system with downconverter PXI 5600 and PXIe-5641R IF Transceiver.
Labview Real-Time 8.6.1
Does anybody know how to repair this problem? I already uninstalled and re-installed these components.
Thank you in advance for any help that you can provide,
Rocio
10-25-2010 11:20 AM
Hello Rocio,
Here is what readme says
Application Development Software
If you are developing applications for the RF vector signal analyzer, you must install at least one of the following application development environments:
Hence if you are using 5660 it is not support with this driver. Also version of LabVIEW you need is 8.6.1
Since you have tried uninstalling and reinstalling, the driver, can you manually search niRFSA.dll in your computer? If you cannot find it, then you might want to reinstall it again, NI do have drivers online for free. Also check this document and see if it helps.
If you do find the niRFSA.dll then make sure you have access to that machine as an admin. something that can stop it from running program. Also can you run RFSA example not NI 5600 one and see if you still get the error.
Good luck !
Lab
10-29-2010 10:27 AM
Hello Lab,
I have the NI 5600 only (not the 5660) but I see what you are saying about the Real-Time Module 8.5.1 and above not supporting the 5660. Thank you for your reply.
-Rocio
