RF Measurement Devices
Error-1073807343 occured at ni scope initalize
Hello Friends,
I am using the PXI-5600 RF downconverter. While running the Demo pannel of the RFSA. I am getting the following Error code-1073807343. The Description of the error code possible reson is (Insufficient location information or the device resource is not present in the system).I associate the downconveter( 5600 ) with the digitizer ( 5142 ) in the MAX. I am getting the Same error in the 5600 soft pannel. I am attching the error code.Can u give the Solution for this problem as soon as possible.
With Regards
Niranjan.
(6,180 Views)
Were you able to get the 5600 to work? Did you try running the self-test for this device in MAX?
Now Using LabVIEW 2019SP1 and TestStand 2019
(6,160 Views)
hi
 Thanking u for giving reply.Yes i did the self test of the 5600 and 5124 both devices selftests are passed.
Regards
Niranjan.Ch
(6,156 Views)
