RF Measurement Devices
How to include required hardware drivers (eg Agilent E5515C) to installer?
Please advice how to include the reqiured instrument driver to the installer?
Message 1 of 14
(10,183 Views)
Hi Eva,
Many instrument drivers that are specifically for LabVIEW are simply a group of VIs. Most of the time, when you use these VIs in a project, they are automatically included under Dependencies. LabVIEW should add only the VIs you used in your project and you can see what gets added by expanding Dependencies.
I’m not sure about the E5515C, but if it is similar to most drivers for Agilent equipment, you can probably manually add the libraries (.LLB) to the project under My Computer. By dragging and dropping a .LLB on My Computer in your project, you should see a folder created and that folder should contain all the VIs in that .LLB. These can then be set as source files in the installer and will be place on the target machine.
Finally, if your ultimate goal is to have the instrument driver installed on the target machine in the same way as it is on your development machine, this is probably best left as a separate install. The information in the two above paragraphs is relevant to simply distributing a working application not recreating a development environment.
Charlie M. CLD
Message 2 of 14
(10,172 Views)
Thanks Eva,
       I can see my instrument .dll file and all of the vi files under dependencies but I still get a message looking for the dll when I run the executable. Any ideas on that? thanks
Message 3 of 14
(9,892 Views)
HI,
    Can you help me about my AGILENT 8960 (E5515C) Which not working.the interface connection must be connected but i dont know what kind of software i need to install?please let me know how to run it.it is (GPIB) please help me to find software for this.
thank you very much,
Albert Sipat
Message 4 of 14
(9,057 Views)
hi mr.charlie,
              please help me for my agilent E1962B i counld not find the software for this equipment and i know also how to used it.please help me to find the instructiion how to used and sofware for GPIB.
Thank you very much,
ALBERT SIPAT
Message 5 of 14
(9,049 Views)
hi mr.charlie,
ALBERT SIPAT
Message 6 of 14
(9,049 Views)
Hi abet,
Please look at this link.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=2392
Sammy Z.
Message 7 of 14
(8,985 Views)
hi sammy,
            thank you very much for your giving idea i will try it then i will let you know if it is work it.
i really appriciate your help.
best regards,
Albert Sipat
Message 8 of 14
(8,979 Views)
hi sammy,
           Good day i try to open which you gave to me but still doesn!t work can you please help me again to find out the WIRELESS TEST MANAGER?i dont know what to do for this equipment.please share to me the installer of wireless test manager thank you very much,
Albett Sipat
Message 9 of 14
(8,947 Views)
Hi Albert,
What is the model number of this Wireless Test Manager?
What exactly do you mean by it not working?  What happens and what doesn't happen?
Did you follow the instructions of the driver on how to use it?
Sammy Z.
Message 10 of 14
(8,938 Views)
