RF Measurement Devices
NI-5600 Usgae in RF Transceiver
For My SDR at one stage i needed to use NI-5600 to downconvert my time domain signal from 2GHz to base band or IF. I wanted to ask how can i pass the waveform of data generated from previous step to my NI-5600 without using to generate anything using  NI-5441. Moreover i also wanted to store the result in the measurment file thereafter.
Thankyou
(6,670 Views)
I'm a little confused about your question. The 5600 is a downconverter that takes your frequency of interest (carrier) and down converts (or upconverts it if needed)it centered at 15MHz. Usually with a bandwidth of 20MHz. This is what comes out of the output port of the 5600... a 5 to 25MHz signal. This is considered IF.
 In order to store this signal it must be digitized. In my case I use the associated 5142.
 I don't understand where the 5441 Arb comes into play? Do you want to recreate your original signal?
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(6,666 Views)
Thanks for the intrest and question. what i want to do is to load the samples data from a file in hardisk to be used by NI-5600 which i am not being able to and i dont want the function generator to generate the function for me. My question was in that context, that how do I load my data of the file and onto the PCI SLot memory or NI-5600 Memory or any other way for which i can use it for NI-5600 computation.
Thankyou
(6,658 Views)
