RF Measurement Devices
How to install inst driver so hey appear in functions Inst I/O pallet
I am trying to install the VI drivers for a Rohde & Schwarz spectrum analyzer into LabView.  I have downloaded the drivers from the R&S website and unzipped them.  How do I install them so they show up in the Functions:Instrumentaion I/O pallet?
(8,815 Views)
These are the plug and play drivers for LabVIEW from Rohde & Schwarz?  If this is the case, which it sounds like it is, the once you have the file unzipped place the folder in the C:\Program Files\National Instruments\LabVIEW x\instr.lib folder, where x is the LabVIEW version.  Once you have placed the folder there, restart LabVIEW and you should be able to access the drivers through the Functions >> Instrument I/O >> Instrument Drivers palette.
Hope this helps!
Andy F.
(8,803 Views)
I faced the same problem when installing FS300 driver into labview7.1, and i tried the solution ,thanks a lot, i found the inst driver in the i/o
pallete, but unfortunately i found question mark boxes <?> appears instead of the *.vi in the FS300 menu, so i couldn't access them ,
i don't  know where's the problem , need help plz.
Thanks in advance
(8,638 Views)
Perhaps you renamed the underlying VIs as described in this post.
Kind Regards,
E. Sulzer
(8,622 Views)
