RF Measurement Devices
Missing LabView VI's for RFSG
I used to have some simple modulation VI's until I downloaded RFSG 1.5. I wanted to get those VI's back. A couple of them were called Generation AM and generation FM. I wanted to look at more simple modulation examples. I tried to look at the ftp site, ftp.ni.com, to find the examples, but couldn't. Please help.
(11,475 Views)
Hey Kevin,
The new RFSG 1.1 uses FGEN 2.3 to do generation. If you go into the Example Finder in LabVIEW and search for FM, you will find "niFgen FM Signal Generation.vi". Also, you can search for AM and find "niFgen AM Signal Generation.vi". These are fairly simple examples. However, they do use Modulation Toolkit that will need to be "reinstalled" after you install RFSG and FGEN.
Sincerely,
Gavin Goodrich
(11,466 Views)
Right, I found those before, but at one time I had several simple modulation files on the NI example finder. 2 of them were specifically called, Generation AM and Generation FM.vi. I was just trying to locate them and could not.
(11,445 Views)
Also, I just found that I don't have the FSK, PSK, QAM.... example VIs.
(11,429 Views)
Hi Kevin,
I recommend you upgrade your NI-RFSG driver to version 1.1. Once you do this, or if you already have, uninstall and reinstall Modulation Toolkit and then you should have a new suite of better RFSG examples installed at:
C:\Program Files\National Instruments\LabVIEW 7.1\examples\Modulation\RFSG examples
Andy
(11,427 Views)
Andy
I am having a similar problem.  I have uninstalled and reinstalled the Modulation Toolkit that accompanied our PXI and the required subvi's are still missing.  In addition, the Functions pallette is missing the RFSG and ni5660 as well.
Please help.
Thank you!!
Jennifer
(10,971 Views)
Hi Jennifer,
What version of LabVIEW do youhave? 8.0 or 7.1?
I would recommend installing the latest version of NI-FGEN, NI-SCOPE, NI-5660, NI-RFSG and then Modulation Toolkit.
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(10,953 Views)
