RF Measurement Devices
Install niTuner on x64 and use with ni5660 -
Hey community,
I've got the problem that I need to install niTuner on a x64 OS system. In another thread it's told that this should not work. I just wanted to discuss about that and actually why it is not working for only this constellation.
I use some ni5660 VI's and they are all using the niTuner VI's. Problem is the DLLs (nipxi5600u.dll and nidaq32.dll) which the niTuner is using, want be initialized. niTuner can't be installed on x64 am I right?
(6,461 Views)
Hi dudeDont,
i checked the Readme of the NI RFSA 2.4.5
NI-RFSA 2.4.5
http://www.ni.com/download/ni-rfsa-2.4.5/2472/de/
It should not be a problem, since it is supported on 64bit Systems.
I hope this helps
(6,444 Views)
From the linked readme:
he following table shows which hardware products are supported under particular operating systems.
Hardware Product
Windows 7 (32-bit)/
Vista (32-bit)/XP 1
Windows 7 (64-bit)/
Vista (64-bit)
NI PXI-5600
NI PXIe-5601
NI PXIe-5603
NI PXI-5660
X
NI PXI-5661
NI PXIe-5663
NI PXIe-5663E
NI PXIe-5665
so, no support for 5660 on x64...
when you see 5600 supported, that is referring to niRFSA driver supporting 5661 in downconverter-only mode. no 5660 VIs can be used on x64 system.
hope this helps!
(6,441 Views)
so sorry. i missed that one x !
(6,436 Views)
