RF Measurement Devices
Is it possible to download I & Q data generated by LabVIEW into Agilent's ESG series signal genarator
Dear Sir,
                Primarily i'm interested to generate a test signal specific to a wireless standard. I'm using LV 8.5 version, and i've Agilent's ESG-D series Signal Generator (E4433B). My Question is, Can i directly run my VI to generate I & Q data and connect it Signal Generator to get the required RF output?
(6,473 Views)
Kamesh,
 you posted to the wrong forum as this one is for NI specific devices. You would probably get more responses if you posted to the Instrument Control forum. Anyhow there is a LabVIEW driver available for your instrument located at:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=405
I don't have LabVIEW on this computer so I don't know for certian if the driver supports direct I/Q but it probably does.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(6,468 Views)
Thank you
(6,454 Views)
