RF Measurement Devices
RFSA digitizer vertical range
hello i'm 5661 french user, i have a problem and need help !
for some weak signal, i need use low vertical range on digitizer (5142).
with RFSA 2.1, there is a option tu change it but it doesn't affect anythings when entering 0.2v value in property node
what am i doing wrong ?
thanks for helping
regards from france
Il a LabVIEW, il a tout compris !
(6,164 Views)
Hi BEU,
can you please explain a bit more what is your problem?
Maybe you can attached your vi or project.
Regards
Yann C.
France
(6,146 Views)
