RF Measurement Devices
What is the Adjacent Channel Power Ratio performance of the PXI-5661
Hi All,
Has anybody had experience with measuring ACP for a signal of 16kHz BW at 25kHz offset, with the PXI-5661?
My customer wants to confirm the PXI-5661's ACP performance before he commits to purchasing.
Also,
How would you estimate the ACP performance of an Analyser for any given channel spacing and bandwidth.
Cheers
Tim
Message 1 of 10
(9,088 Views)
Hi Tim,
We are running some tests on the 5661 for you to see what ACP we are getting on our end in order to post some results. We will be using the 5661 to acquire the data and the ACP vi from the Spectral Measurement Toolkit to analyze the results. Did you have a specific carrier frequency in mind?
Steve
Steve B
Message 2 of 10
(9,061 Views)
Hi Steve
Thats fantastic thank you!!!
The frequencies of interest would be:
175MHz
512MHz
1000MHz
Cheers
Tim
Message 3 of 10
(9,056 Views)
Hi Tim,
In order to be able to successfully test ACP with the 5661, we need to know the carrier frequency, channel properties ( BW ) and properties of the adjacent channels ( BW, separation from channel of interest and carrier frequency).
I'm assuming that the frequencies you supplied 175 MHz, 512MHz and 1000MHz, are your carrier frequencies.
Can you please verify the other info?
Best Regards,
Faris A
Bueller
Message 4 of 10
(9,031 Views)
Hi Faris
Carrier Frequencies of Interest are:
175MHz
512MHz
1000MHz
Channel Spacing:
25kHz
Bandwidth
16kHz
Type of Signal:
Narrow band FM
Cheers
Tim
Message 5 of 10
(9,019 Views)
Hi Tim,
Attached is a spread sheet containing the measurements I have taken at the different center frequencies.
I generated an FM modulated signal with 16KHz BW  at different power levels. And I measured the ACP.
It is worth mentioning that cable I was using was introducing some attenuation.
Hope that will help.
Best Regards,
Faris A
Message Edited by Bueller on 12-19-2008 08:43 AM
Message Edited by Bueller on 12-19-2008 08:47 AM
Bueller
Message 6 of 10
(8,988 Views)
The excel spreadsheet sems to have power column mislabled. The Adjacent channel power is probably dBc and not dBm as labeled in the spreadsheet. Can you confirm?
Message 7 of 10
(8,978 Views)
All units are in dBm.
Best Regards,
Faris A
Bueller
Message 8 of 10
(8,934 Views)
Tim ,
I took a look at the spreadsheet. I forgot to add the device attenuation to the adjacent channel power. I will post those numbers again.
Sorry for the confusion.
Best Regards,
Faris A
Bueller
Message 9 of 10
(8,926 Views)
Here's the final list
Message Edited by Bueller on 12-22-2008 12:15 PM
Message Edited by Bueller on 12-22-2008 12:16 PM
Bueller
Message 10 of 10
(8,919 Views)
