RF Measurement Devices
Noncoherent FSK using 5421
I'm trying to generate a user bit pattern (not PN sequence which is found in most of the MT examples), modulate FSK on FGEN 5421 board.
Then from 5122 scope, FSK demoduate and recover the generated bits. However, I am having a difficulty in doing this. The recieved bits are all
junk.  I looked at the simulated FSK Transceiver and others, but there's no example that simply generates bits and receiving bits with FGEN and SCOPE.
Also, I couldn't find any non-coherent FSK examples.
Here's the specs:
Carrier Freq: 3MHz
Modulaton Index: 1
Symbol Rate: 64Kbps
MARK: +32KHz
SPACE:-32KHz
Modulation Scheme: FSK
I'm attaching the program that I've been working on.
Any help would be great. Thanks
(7,981 Views)
The problem's been solved.
You can disregard this message.
(7,977 Views)
hi,
    we are doing fm modulation and demodulation. we are using a 5661 analyzer and a 5672 signal generator.
    we also want to fsk modulate  and demodulate but user defined bits not pn sequences or randomly generated bits. could you send us the corrected code.
 thankyou.
(6,564 Views)
(6,564 Views)
