04-12-2012 08:40 PM
Hi Dileep Karwa Kumar,
So far, I have modified two of the example VIs: MT RFSG Generate PSK and RFSG Finite Generation - Re-triggered. I got some input from one of our more knowledgable RF engineers here at NI, and he agreed that the easier route is to go with my original impulse, and modify the MT RFSG Generate PSK, converting it to PSK burst. I am still finishing the code and testing it to make sure that this process will work. I will keep you updated.
Best Regards,
04-13-2012 12:51 PM
Hi
Andrew M
I am really thankful to you . In the start I also tried to edit "MT RFSG Generate PSK", take help from "MT FGEN PSK burst generation" and use "mod_BB-PSK generation (one-shot).vi" But I didnt work, I guess I was missing something. But I am sure it can work.
Ragards,
Dileep Karwa Kumar.
04-17-2012 04:54 PM
Attached is a modified version of MT RFSG Generate PSK to do burst generation. Just to make sure I set your future expectations properly, NI application engineers do not normally create or modify code for customers. However, this application interested me, so I wanted to see if I could get it working. I have not fully tested it, this is just meant to be a beginning to get you started. I hope this VI will help you to get your application working.
Legal
The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
Best Regards,
