RF Measurement Devices
RF bluetooth
Hi
I would like to know, can i use the RFSG/RFSA to test bluetooth devices,  & WLAN,
if yes , what are the limitations.
rags
(8,743 Views)
Hi Rags,
I think this KB Does the NI PXI-5660 RF Signal Analyzer support Bluetooth measurements? should answer most of you questions on Bluetooth - the caveats would also aply to RFSG. Its going to be a very similar situation with the wireless networking standards, as far as our devices and the Modulation Toolkit would be able to demodulate the signal as long as it stayed within the bandwidth and frequency range of our devices.
Hope this helps, please post back if you have any additional questions.
Cheers,
Andrew S.
(8,725 Views)
Sorry, messed up the URL - try this one - Does the NI PXI-5660 RF Signal Analyzer support Bluetooth measurements?
Cheers,
Andrew S
(8,723 Views)
Hi Andrew,
Thank you for the reply & the suggestion,i went thru the web link,
as mentioned do i need to take up the third party packages, or
can i meet most of the, most of my requirements using NI software & packages
rags
(8,715 Views)
Hi Rags,
You would need a NI 566x for acquisition, a NI 567x for generation, and the Modulation Toolkit. You would also need a PXI chassis and some form of controller, but you would not need additional third party software or hardware. In order to perform the tests, you would need to have an in depth understanding of the Bluetooth standard, and a good understanding of LabVIEW and RFSA/RFSG programming. It would require additional LabVIEW programming to build tests that are relevant to Bluetooth and the specific measurements you require.
One of our Alliance Members built a Bluetooth testing application. Also, if you are looking for a system customized for Bluetooth, AmFax PXI-Based Bluetooth Measurement Suite uses our hardware and has vi's made specifically for Bluetooth testing. There are several other Alliance Members that have custom solutions that work well with LabVIEW, and save on development time. You can search through the Alliance Members to find one that fits your needs.
Cheers,
Andrew S.
Message Edited by stilly32 on 01-30-2007 01:44 PM
(8,702 Views)
Hi Andrew,
sorry for the late reply, thank you
i will go thru the links and get back to you later
rags
(8,673 Views)
