RF Measurement Devices
Sub VIs missing to use NI-5660 VIs.
I want to demodulate FSK using NI-5660. but in the required VI like the "configure for spectrum.vi" there are some sub VIs missing.  any suggestions on what to do.  i use labview 7.2 (also tried with 8.0 and 8.2).  modulation toolkit 1.0.  RFSG and RFSA drivers are the latest ones available on net.
(7,260 Views)
sorry about that, but the modulation toolkit version is 3.0.
(7,250 Views)
Om,
Thanks for contacting National Instruments support.  Is the issue you are running into in an exmaple vi, or this a vi you are trying to make?  Any needed vi's should be there when you install the Modualtion Toolkit.  What was your method of installation?  Were there any errors or abnormaliites during the install?
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(7,238 Views)
