RF Measurement Devices
RFSA 5663
What is the noise bandwidth of RFSA 5663???
(6,627 Views)
When it comes to 5663 VSA we talk about equivalent noise bandwidth (ENBW). The equivalent noise bandwidth of 5663 VSA will be dependent on the settings you select (e.g. FFT window type). Refer to the following article for more details:
NI 5663/5663E Noise Figure - NI RF Vector Signal Analyzers Help
Mikhail
RF Toolkits, Product Support Engineer
(6,619 Views)
Thanks for your reply.
How about this below specification of RFSA? What is it use for?
Tuned Frequency                              Equalized Bandwidth
10 MHz to<120 MHz                            10 MHz
120 MHz to<330 MHz                          20 MHz
330 MHz to 6.6 GHz                          50 MHz
I'm measuring a GPS signal at 1176.45 MHz, so its noise BW is at 50MHz, is that correct?
Because, i'm measuring a GPS signal which is very low around -130dBm
Want to know how much gain the RFSA 5663 can provide before applying any external amplification....
Also, can we detect how much gain the 5601 amplifiers/mixer is providing before it goes out as IF signal...
(6,607 Views)
The equalized bandwidth refers to the bandpass bandwidth of the filter on the RF front end of the 5663 device. The equilized bandwidth will vary based on the LO setting. For LO setting within 330 MHz to 6.6 GHz, BW = 50 MHz. Refer to the this diagram for more details. Noise is linked to the RBW (resolution bandwidth specification). "The effective noise bandwidth (ENBW) is generally used for noise level measurement because the shape of the real RBW filter (IF filter provided at the last filtering stage in an analyzer) is not completely rectangular. Effective noise bandwidth (ENBW) is normally represented by k x RBW, where factor k is determined by the shape factor of RBW filter" [1]. To determine how much gain the downconverter applies to the signal you can read the following property, NIRFSA_ATTR_DOWNCONVERTER_GAIN either through LabVIEW or CVI. Refer to the following post for more details: PXIe-5663e block diagram - NI Discussion Forums
Mikhail
(6,593 Views)
Thanks a lot for this information, it really have clear explanations.
However, is there an available table where there is corresponding ENBW for each RBW for NI RF VSA products just like the Table 2 of Agilent product note for the different analyzer models....
(6,582 Views)
Unfortunately, we do not have a similar table for 5663. All the specifications that are public are listed in the NI PXIe-5663E Specifications - National Instruments
Let me know if you have further questions.
Mikhail
(6,562 Views)
