RF Measurement Devices
SOQPSK implementation
Hi All,
I have Modulation Toolkit 4.3 and would like to implement SOQPSK according to IRIG106. I poked around a bit within some of the example programs and saw that there were some Offset and Shifted PSK modes available, but as SOQPSK can be somewhat of a monster, I wanted to ask the community if anybody has tried this with LabVIEW and MT.
As far as hardware, I have an NI-USRP but would consider other NI hardware if the implementation required it.
Thanks!
(6,178 Views)
Hi DrSpaceman,
Are you looking to transmit or receive (or both) SOQPSK? We currently do not have anything in the modulation toolkit that implements SOQPSK. However, if you have previously written any simulation code which implements SOQPSK, then you might be able to take advantage of MathScript to implement your .m file.
Kaitlin N.
(6,144 Views)
