RF Measurement Devices
Real-Time Desktop Validator
There is information describing a "Real-Time Desktop Validator" to check the hardware on a PC for real-time compatibility here, but most of the links on the page are inop, and I can't find the utility. Does anyone know where to get it? I'm in the process of putting together a desktop for RT use and would like to try it out.
Rod
Message Edited by Rod Don on 08-11-2006 06:44 AM
(8,859 Views)
Hi Rod,
It looks like the link to the utility isn't quite live on the website yet.  The KnowledgeBase article that contains the Real-Time Desktop Validator and how to use it can be found here when it is posted.  The link should be working soon, so please keep checking that URL.  Hope this helps!
Thaison V
(8,823 Views)
I found a utiltity here - is this the same one?
It's still not available at the link I listed above.
Rod
(8,734 Views)
Hi Rod,
Yes, the link you found is it.  The URL must have changed since it went live.  Let us know if you have questions about it!
Thaison V
(8,727 Views)
