RF Measurement Devices
SERIAL PORT and PC COMMUNICATION And Arrays
I Made RF transmitter and receiver. I'm taking data from rs232 port and I can make monitor in Hyper Terminal or RS232 Analyzer. I want to make monitor in Labview. I can see DATA in labview. but İt is coming so slowly and while byte count 10, Labview take 10 bytes after then data is slide. For example;
First coming 127127225 after 271272251 after that 712722512 after that 127127225
I want to take data as seperate and ı want to give name to data. for example;
Pulse = 127 ; OXYGEN Saturation = 127 ; Temperature Room = 22.5
What can I do? Am I use should array? Thank you...
(6,063 Views)
Duplicate post of:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Connection-between-RS232-AND-PC/m-p/1124982#M...
http://forums.ni.com/t5/RF-Measurement-Devices/SERIAL-PORT-and-PC-COMMUNICATION-And-Arrays/m-p/11250...
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,597 Views)
