RF Measurement Devices
SP8T pin diode switch control
Hi, I have a SP8T pin diode switch and I would like to ask how can I control the switch via labview? e.g the TTL control. Thanks!
(5,921 Views)
Hello ghost,
It seems that unfortunately your post has remained unanswered for a very long time.
Is this issue still open or have you been able to find the answer in a parallel way?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,761 Views)
