RF Measurement Devices
Sound sensor for calibration
Can someone suggest some good microphone or sound sensors for calibrating the noise from a motor. We are listing the noise from inside the small pump when the stroke is touched to mechanical parts. To make avoid this, I want to use some sound sensors to adjust. I am first time entering in these sensors. Please, some one suggest some ideas.
                                            Thank you.
(5,763 Views)
Hello Ivan,
I'm currently trying to answer all previously unanswered posts on this forum category.
This post however seems to be misplaced.
I also see that you have had alot of other posts on the forum (400+), so I will assume that you had your question answered in another forum category.
If this was not the case, then please just let me know.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,668 Views)
