RF Measurement Devices
Trigger line requested could not be reserved because it is already in use.
Hi , I am trying to export markers on PFI0 and PXI_Trig0 on NI5450 (in the script mode)
using the following code
There are no errors when I configure using the following code.
commWrapper.ExportSignal(PXICommonGenWrapper.niFgenConstants.MarkerEvent, "Marker1", "PFI0")
commWrapper.ExportSignal(PXICommonGenWrapper.niFgenConstants.Marker, "Marker0", "PXI_Trig0")
When I run the script, I get the following error
Property: Marker Event Output Terminal
Destination Device: PXI1Slot2
Status Code: -89126
Would appreciate any solution that enables to me configure the two triggers/markers. I use these markers to trigger another PXI card (NI5644R on PXI_Trig0) and an external piece of equipment (using PFI0 output).
Thank you.
(7,180 Views)
Accepted by spappu28
Hi Surya,
Thanks for posting this on the community page. What this error is telling you is that it can't route a trigger to your requested destination because something else has already reserved that trigger line. One pottential typo is that your second ExportSignal command specifies niFgenConstants.Marker and not .MarkerEvent. This is a simple error to resolve but there are many possible sources. Is it possible for you to share the full code with me? Or,maybe you could host a join.me session and I can look at your full setup.
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(7,174 Views)
