RF Measurement Devices
fetch and write IQ data in chunks
I'm trying to fetch and write IQ data in chunks using the attached vi.
I'm using the following devices to perform the acquisition:
- NI PXI-5600;
- NI PXI-5122, with an on-board memory of 1GB, corresponding to 512MB per channel, 256MSamples (per channel). So I can acquire a maximum of 2.56sec of continuous acquisition, since the device sampling rate is 100MS/s.
After the IQ conversion, I need to store data on my hard disk. Because of the limited transfer rate of the bus, I can't perform this storage in only one step, so I'm trying to use fetching in chunks.
The problem is if I change the value of Fetch Chunk Size parameter (without changing the time duration parameter), the Number of I (Q) samples changes, and also the size of the I (Q) files created changes.
I think the problem is in the MT Convert IF to IQ.vi, but I'm not sure.
How can I solve this problem?
Thank you for collaboration, I hope you answer me as soon as possible.
(7,633 Views)
Hello bongio,
I see that this question has remained unanswered for a very long time.
Is this issue still open?
If yes, then just let me know, so that I can try to help you further.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,930 Views)
The described issue has been solved long time ago.
Thank you for you interest.
(5,898 Views)
