RF Measurement Devices
graphs fine on screen - no data when printed
I take some temp readings and display them on a graph. Everything is normal and looks fine. When I print the window only the frame and border get printed - the data isnt there. It is like the data got assigned some kind of "clear" attribute. I get the same results on several different installations. It used to work a few months ago. what is going on ? Some demo or sample vi work fine when I send window with data on a graph  to the printer - help??
(6,894 Views)
Which version of LabVIEW are you using?
Please see if this article helps: Why Is the Data Missing When I Print a Graph?
If not, could you attach your VI that doesn't print correctly? Also, how are you printing the VI: using File -> Print or doing this programmatically?
Thanks and best regards,
Shakhina P.
(6,882 Views)
