RF Measurement Devices
ni5660 Peak Search - Build Error
Dear Sir:
I modified ni5660_Peak_Search.vi.
I added more markers and extended the waveform diagram for convenient browsing. And this vi works properly.
When I tried to build it, it showed a error as below:
"The following files have links to help files that are invaild.Open the files and fix the help links.
C:\program files\national instrumentd\labview 8.0\instr.lib\niScope\Calibrate\niScopeCal.llb\niScope Cal Get FR Eeprom.vi "
Actually I did not touch this file so I cannot figure out why it show up.
Please help me? Thanks a lot.
My environment
LabView 8.0,RFSG1.2,RFSA1.5,niScope 2.9.2f4,niFGEN 2.4.0,niVISA 3.5.1,niDAQmax8.0.0f0
(7,409 Views)
FW00,
I took ni5660_Peak_Search.vi and was able to successfully build it on my machine.
The VI "Scope Cal Get FR Eeprom.vi" is part of the NI-Scope drivers but it is a subvi of both "SMT Configure RFSA for Spectrum.vi" and "MT Configure Downconversion Settings (RFSA).vi" both of which are subvis of ni5660_Peak_Search.vi.  I discovered this by using the VI Heiarchy option and finding the Get FR Eeprom VI on the 6th row.
It sounds like something did not install correctly or has been corrupted.  My environment is exactly the same as yours except I am running NI-Scope 3.1.0, VISA 3.6, and DAQmx 8.3.
It sounds like an uninstall/reinstall may be in order.  You may want to start by upgrading NI-Scope to the latest version and seeing if that fixes it.
(7,394 Views)
Yes, I upgraded to niscope 3.1.0f4. Then the error was disappeared.
Thanks for help.
(7,365 Views)
