Random Ramblings on LabVIEW Design
Community Browser
Labels
swatts
25 Comments
For a splash screen to get the title GROOVY it needs to have a strange shape, exhibit the right kind of transparency, fade in and have some nice custom progress stuff going on.
I laugh in the face of rectangles!!
So to cure the world of SQUARE software here's how to do it, code will be posted somewhere. Download SplashScreen2013.zip
Tools
You will need Paint.NET
And LibreOffice
And LabVIEW 2013
The LabVIEW bit
You will need to dynamically load the splash screen and then some time after the main program. For a nice fast start up we want to load the main program in the background and then show the front panel.
Startup VI
DynLoadSplashscreen.png1st Dynamically load and run the splash screen
DynLoadMainscreen.pngThen start loading the main program
BringUpMainscreen.pngAfter a bit of a wait bring up the main screen
CleanUpSplashscreen.pngand tidy up the splash screen
Splash Screen
This is the pretty bit, first lets get the graphics. Cut and paste the image into Paint.net and use the magic wand tool.
MagicWandTool.pngThis selects a block of colour that you can delete (make transparent), Delete any thing else that you are going to replace. In this case I deleted the progress, version and link to the website.
Next we load this into our splashscreen VI by Edit>>Import Picture to Clipboard... like thisSplashscreen vi.png
The progress indicator is simply a ring control made from a rotated metafile created in LibreOffice.
Green Screen Transparency
Now the clever bit is that we do not use the property FP.Transparency for this as this is mostly for fading in and out, we're after a green-screen affect where the background colour is masked.
For this we need to use some Windows functions (I've no idea what the Linux and Mac methods are..sorry).
We need User32.dll>>FindWindowA - gets the window handle
User32.dll>>GetWindowLongA - Retrieves information about the specified window. The function also retrieves the 32-bit (DWORD) value at the specified offset into the extra window memory. We're after extended windows styles..
User32.dll>>SetWindowLongA - Changes an attribute of the specified window. The function also sets the 32-bit (long) value at the specified offset into the extra window memory. The window is a layered window
User32.dll>>SetLayeredWindowAttributes - Sets the opacity and transparency color key of a layered window.
I don't know where I got this from, it certainly wasn't down to my own hard work.
This can be quite easily grabbed and moved about (bit of mouse down event jiggery-pokery, click on button 2 and drag it about).
So now you have no excuse for dull rectangle LabVIEW, we like Wonky
Hugs and Kisses
Steve
swatts
9 Comments
If you saw me doing Fab`s presentation "How to Polish Your Software and Development Process to Wow Your End Users" I'd like to apologise for making you uncomfortable, ah who am I kidding! I found it very funny indeed. Just to explain I stopped for 30 seconds just before talking about splash screens, causing lots of uncomfortable seat shuffling and worried looking attendees. Had a very good day, thanks to all who worked so hard.
In the last blog I laid out that you will likely be hit with changes at the most inconvenient time in a project i.e. at the end. This got me to thinking about one of the key benefits of visual programming and that is Rapid Modification. Some call this debugging and Glass rather directly (and accurately) calls the process error removal. The trouble with both of these terms is that they have the taint of failure about them. So if you are debugging you must be an idiot for putting bugs in in the first place!! Error removal!, WHAT I DON'T PAY $xxx/hour FOR YOU TO PUT ERRORS IN! I think you know where I'm coming from.
With a software project the standard view is that maintenance is a significant part of the cost of a project (40%-80% from various studies, 60% is an average), and a majority of this cost is not error-removal but adding new capabilities. Adding new capabilities and rapid modification is a positive thing, successful software is modified.
So a more grown-up view is that modification at the end of the project is normal, and if like us, you classify maintenance as the phase that begins from the moment you deliver the software to the customer that 60% doesn't sound so extreme. In short this is a very very important part of the software process and making this easy for ourselves will pay big dividends.
What is the debugging process?
  1. Reproduce...Observe the process,Understand the problem
  2. Diagnose....Visualise the process
  3. Fix....Introduce a change
  4. Reflect....Test the change
As I mentioned earlier LabVIEW has some help to give us and this is one of its fundamental advantages.
The block diagram is an enormously powerful visualisation tool, cherish it please.
Probes, breakpoints, execution trace are all helpful.
Searching (please improve it NI), even with it's limitations it's sooo useful.
We can also help ourselves, here are some techniques to use..
Reading Before Writing...
Harlan Mills has it right, software should primarily be designed to be read. The decision to sacrifice readability is an expensive one (not necessarily for the original developer, but definitely for anyone else involved in the process)
Labeling Loops
Labeling Cases
Bookmarks
Type Defs
Enumerated Types
Putting control in event case rather than just leaving it floating, that way the event is only a click away.
Comprehension is the most important factor in doing maintenance
Ned Chapin 1983
Design with maintenance in mind....
Part of the design process is to think about how our design affects the various aspects the project lifecycle.
  • Scalable
  • Modular
  • Reusable
  • Extensible
  • Simple
The SMoRE acronym is used quite a lot, the trick is to adjust how much you concentrate your design efforts on where you get maximum benefit. I have removed Extensibility from my projects because they were pushing the hierarchy too deep and this was affecting Simplicity and Reusability.
Cohesion
Encapsulation
Keeping hierarchy as shallow as possible, you don't want to be trekking through layers and layers of abstraction to find the logical decision that tackles the problem. At my age I often walk into a room to do something and then completely forget what it is. Now if Watts Towers had 25 rooms that I had to walk through 1st it is very likely I would be in this situation more often! For all my facetiousness this is a very important point. I want to rapidly get to the point of logical decision and this process has to flow, anything that inhibits this fluidity makes visualisation harder and me grumpier.
Another important facet of visualisation is getting the solution to represent the problem, this relatedness is very important to simplifying your code. This is why I'm wary of all this talk of patterns, I fear the day when I come to sort out a job and I'm presented with Factory Patterns, Singletons, Facades etc etc when all I'm looking for is the bit telling me what the software is doing and when. All these things have their place, but if they hinder debugging they are costly indeed.
Using searchable structures like Controls and subVIs. The Constant VI is a very good example of this as a technique.
Exercise some constraint when using dynamic loading and dynamic dispatch. Especially where the dispatched vi change the functional decisions of the software. In my experience dynamic dispatch can simplify a block diagram if used correctly, but if the method changes the function of the software it can act as a block to visualisation.
I might do some funky graphics stuff in my next article.
Hugs, Kisses and Psychedelic Shirts to you all
Steve
