61056 Error massage
Hi all
   I have questions on FPGA module. I have FPGA board 7833PCI and try to make some square wave out of Digital Output.  When I use my timed loop, I get the error massage saying 61056  Component ddata16_res has invalid arbitration for single-cycle timed loop & 61056  Component denable16_res has invalid arbitration for single-cycle timed loop.  I thought maybe my program has some problem so I tried the test 40mhz.vi posted on this disscussion forum.  it gives me the same error while compiling.  Is there something wrong with my board?  I also tried boolean array of 010101010101010101 in while loop and write to digital output.  This one also gives me 5Mhz as the fastest frequency I can generate and it does not look anything like square wave.   How can I get faster frequency output?
Thank you very much in advance
Hideya
(3,232 Views)
Hideya,
Have a look at this Knowledge Base article:
Code Generation Error 61056: Invalid Arbitration for Single-Cycle Timed Loop
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(3,211 Views)
