Hi all
I have questions on FPGA module. I have FPGA board 7833PCI and try to make some square wave out of Digital Output. When I use my timed loop, I get the error massage saying 61056 Component ddata16_res has invalid arbitration for single-cycle timed loop & 61056 Component denable16_res has invalid arbitration for single-cycle timed loop. I thought maybe my program has some problem so I tried the test 40mhz.vi posted on this disscussion forum. it gives me the same error while compiling. Is there something wrong with my board? I also tried boolean array of 010101010101010101 in while loop and write to digital output. This one also gives me 5Mhz as the fastest frequency I can generate and it does not look anything like square wave. How can I get faster frequency output?
Thank you very much in advance
Hideya
