6534 Real Time Problems?
in our application we use a PXI-6534 card to aquire datas. With 20MHz we are aquiring 32 bit datas. We have several applications like this which run without problems. But now on the current project we have problem and we don't know why.
When we create test signals and read them in the 6534 we have several failures, that means bits which are not correctly read. Because we have 3,3 Volt signals and the 6534 is a 5V card we expected that the problem is there. But now we are thinking that it can be also that we broke the real time.
Parameters:
- Input data
- clock frequency 20MHz
- 32 bit
Does anyone know if the 6534 is able to aquire datas really up to 20MHz?
Thanks in advance
Oliver
Message 1 of 1
(3,438 Views)
