9220 with cRIO-9064
I am trying to use the example "NI 9220 User-Controlled IO Sampling.lvproj" originally made for cRIO-9101 with cRIO-9064 under NI LabVIEW 2014 SP1 (32-bit). The NI 9220 "User-Controlled IO Sampling (FPGA).vi" declares the errors: “Read I/O Method: XNode is not executable” & “Read Status Method: XNode is not executable” with Details: “This node is not executable because an unexpected error occured during code generation.” The LabVIEW Help offers, among others, two solutions: "Remove the XNode from the block diagram" & "Re-add the node to the block diagram." Please help: How can I remove or re-add the XNode or what else could I do?
(2,757 Views)
Accepted by topic author Korto
To solve this, the broken Read I/O Method and Get I/O Read Status Method nodes should be deleted from the block diagram and replaced with new ones from the Functions palette,
Kind regards,
Vilius
(2,540 Views)
Great. Functions perfect. Thank you, Vilius!
(2,535 Views)
