pyvisa in linux seems not working
Hi guys just in case anyone of you tried control equipment in virtual machine before may help me
I got Win10 as host and Centos7 as guest in VMware,  in host Win10 pyvisa talk to equipment very well, everything is working.
But in guest Centos pyvisa seems not able to retrieve any ethernet connected equipment.
pinging to equipment ip address from guest OS  shows connected:
(base) [aaronfan@localhost ~]$ ping 10.0.22.30
PING 10.0.22.30 (10.0.22.30) 56(84) bytes of data.
64 bytes from 10.0.22.30: icmp_seq=1 ttl=128 time=0.814 ms
64 bytes from 10.0.22.30: icmp_seq=2 ttl=128 time=1.19 ms
64 bytes from 10.0.22.30: icmp_seq=3 ttl=128 time=1.44 ms
64 bytes from 10.0.22.30: icmp_seq=4 ttl=128 time=1.25 ms
64 bytes from 10.0.22.30: icmp_seq=5 ttl=128 time=1.08 ms
^C
--- 10.0.22.30 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4008ms
From guest Centos pyvisa-info I don’t see anything wrong either, Guest OS pyvisa-info:
Machine Details:
   Platform ID:    Linux-3.10.0-1062.el7.x86_64-x86_64-with-centos-7.7.1908-Core
   Processor:      x86_64
Python:
   Implementation: CPython
   Executable:     /home/aaronfan/miniconda3/bin/python
   Version:        3.7.5
   Compiler:       GCC 7.3.0
   Bits:           64bit
   Build:          Oct 25 2019 15:51:11 (#default)
   Unicode:        UCS4
PyVISA Version: 1.10.0
Backends:
   ni:
      Version: 1.10.0 (bundled with PyVISA)
      #1: /usr/lib/x86_64-linux-gnu/libvisa.so.18.2.0:
         found by: auto
         bitness: 64
         Vendor: National Instruments
         Impl. Version: 18874880
         Spec. Version: 5244928
any ideas welcome , thanks.
Message 1 of 1
(1,908 Views)
