After Upgrading LabVIEW 2013 SP1 and Xilinx 14.4 my FPGA Compile Worker will not start.
I have been using a local remote server to compile my FPGA code. After receiving the NI Developer Suite update DVD's I proceeded to install the new updates to the system(see attached File).  After a successful upgrade I rebooted the server.  When I try to run the “FPGA Compile Worker” nothing happens.
How can I get the FPGA Compile Worker to start?
Regards
Gus
(6,376 Views)
Accepted by gmarz5
Upgraded .NET 4.0 to 4.5 and the problem went away.
(6,367 Views)
had also the same problem and solution, thanks for sharing 😉
(6,317 Views)
I also had the same problem - solved by installing .NET Framework 4.5. In the meantime NI released a patch that should fix this issue:
http://digital.ni.com/express.nsf/bycode/xilinx144f1en
Lucian
CLA
(6,029 Views)
