Array does Not resolve to a Fixed Size error
Hey
I'm using the NI-9223 module. I want to be able to choose which inputs I want to acquire every time I run the VI. For that I used a lot of case structures, I tried on simulation and it functions. But when I tried to compile the code I got this error "Array Does Not Resolve to a Fixed Size".
I thought all of the arrays I used were with a fixed size, but now I'm not sure. Is this error occuring because for each case I have a different array wired to the output tunnel?
And is this case structure the best solution to dinamically choose the inputs?
(833 Views)
You have different lengths of arrays going to the same output tunnel in different cases.  For instance, case 0 has an empty array while case 1 has a 1 element array.  Since the maximum length in the cases is 4, you need to make all of the output arrays a length of 4.  To help your FIFOs, you can also output the number of elements that need to be sent (wire to the N on the FOR loop).
GCentral
(810 Views)
What do you mean "to help your FIFOs"?
(795 Views)
In my opinion, it is a waste of FPGA resources to have multiple relatively similar cases, with only one of them being active and the rest remaining idle most of the time.
I would program to write all 4 channels to the FIFO, then filter the data from selected channels on the host size.
https://tmesystems.net/
(789 Views)
Accepted by euqinom2727
This is good advice.  The only difference I would do is wire up the N to the FOR loops that write to the FIFOs.  Doing this, the FPGA can limit what data goes up to the host.
GCentral
(783 Views)
Thank you guys!
(739 Views)
