Assigning period in timed while loops from local variable
I don't think this is the case. I've selected the 1 MHz clock and the dt in my loop is supposed to be a double. I thought of this as well, but it doesn't connect the wire and lists an error if the data type is different.
Message 11 of 13
(805 Views)
I think I figured it out! Silly mistake. I was assigning a value that created the period to be 1000 seconds, when I thought it was running at 1000 Hz.. So in reality it was actually running the whole time but was so slow it seemed like it was not.
Thanks so much for your help.
Cheers,
-T
Message 12 of 13
(805 Views)
Hello TallGrass
I am glad to hear that. Well done.
Regards
Message 13 of 13
(795 Views)
