Hi to everyone!
From a very Labview beginner:
I'm using a NI CRIO and I need to read analogic signals at 5000 Hz from accelerometers with a Ni 9233 and, at the same time, 13 digital signals coming from an absolute encoder at 100000 Hz with a NI 9401. For the moment everything works in a big while loop in the fpga but I can't of course read the two different signals at their two different rates and, what I haven't understood yet, there's a some tenths of second delay in the display of the encoder position and speed on the real-time panel . According to the FPGA-getting started I should separate the two operations in two parallel loops and I do agree with it but what happens when I read the signals from the real-time VI? How can I set two separate reading rates? At this time I'm reading the data by simply reading from indicators on the fpga VI, is that a good way?I attached the fpga VI and the real-time VI to help you understand my problem. Could you please suggest me a way to make this system much faster?
I really thank you a lot in advance hoping to get an answer as soon as possible!!
Rob_F
