Binary data to FPGA on cRIO
Hi!
I'm a beginner on programming with LabVIEW. I want to read data from a file on my PC. With the Bytes I want to set my digital output port.
The filesize is about 64k. Currently I read the data in a PC -VI. There I write it into a big array. I also created a shared variable array to use it on the cRIO host. On the host a write the data to a control, which is connected on the FPGA with a Memory. This solution works, but it's dirty.
Does anybody know a better solution. Is it possible to read the data from the host VI to save resources?
I want to save the data on the cRIO. Should I make a binary file on the cRIO?
My system: LabVIEW 8.5, cRIO 9014
Thank you for your help.
regards,
demo66
(4,486 Views)
Hello demo66!
About your questions:
=> A Simple TCP/IP connection safe resources. The Shared Variable is easy to program but the performance with TPC/IP is better.
=> Normally a binary file is more effective than an ASCII file.
WolfgangZ
(4,434 Views)
Thank you for your answer!
Do you mean, that I should write the data unique over TCP/IP from the PC to the HOST? Do you have an example for TCP/IP?
What do you think is the best way to transfer the data from the HOST to the FPGA?
demo66
regards,
demo66
(4,424 Views)
