06-02-2016 09:51 AM
We will be using a 9067 chassis running headless in a potentially high vibration environment for several hours. The memory available in the controller is not sufficient for the amount of data we may need to acquire (~2-4 GB?). I have searched for something like a solid state disk drive in a C-series module but have not found anything. I have considered an Ethernet-connected external drive but have concerns about the reliability of the RJ-type connectors under vibration and the inconvenience of having to physically mount another device.
Does anyone know of such a device or what other suggestions do you have?
Lynn
		06-02-2016
		04:49 PM
 - last edited on
		03-25-2025
		10:11 AM
 by
			Content Cleaner
Hi Lynn
I hope the system is progressing well. I was interested in this to see the options - so had a quick look.
This is what I saw:
hope useful
Andy
06-02-2016 06:39 PM
Andy,
Thanks again for your suggestions.
1. Not compatible with the cRIO-9067, but an interesting concept. That is what I was looking for.
3. Looks like a good possibility. And much cheaper. A little silicone sealant (non-acid type) and a few nylon tie straps might work.
The main programmer was pulled off for another project for a while but we did get some smple examples running under Real-time. Now we can begin to focus on the actaul program. If we could just get the researchers to tell us what they really want...
Lynn
06-07-2016 06:04 AM
Hi Lynn,
Another option could be to use a wireless network module
as supplied by sea systems then you could access the data in real time.
The threaded sockets by the UDB A and B ports are for NI's USB leads to meet Class 1 requirements such as 152166-02.
We have had some qualification testing for both shock and vibration using the RJ45 connectors and not had any problems.
Cheers
Stephen
06-07-2016 08:49 AM
Stephen,
Thank you for the information.
The wireless module will not work as we need a 40 mile (64 km) range.
It is good to know that the RJ-45 is robust to vibration. I have seen some connectors fall apart or break connections and was concerned that something similar could happen with the RJ-45.
Lynn
06-07-2016 10:24 AM
Hi Lynn,
There is always 3G/GPS or the 4G/GPS that are also available from SEA Systems if you need 40 miles and the reception is suitable.
Of course this could be complete overkill a M.2 SSD inside a USB enclosure and attached to the USB port on the cRIO via a USB Lead with judicious use of silicone adhesive might be all you need.
Cheers
Stephen
06-07-2016 12:55 PM
Stephen,
I have been thinking about the latter! More along the lines of "copious" rather than "judicious."
Lynn
		06-08-2016
		03:07 AM
 - last edited on
		03-25-2025
		10:11 AM
 by
			Content Cleaner
Hi Lynn,
If you used a M.2 SSD in an enclusure you could then purchase a 196917-01 NI 9977 C Series Filler Module for Empty Slot and mount the SSD enclosure in it. This would in effect be your own custom made data storage module in a C-series module that would not be too expensive. A standard 2.5" SSD does not fit the module without a little extra "engineering".
Using the threaded socket on the cRIO to secure the USB connector you would have an easily removable data storage module that might not have any silicone adhesive - depending upon how you mount the SSD.
Cheers
Stephen
