CRIO 9074 losing connection with network
Would you mind posting the knowledgebase article you referenced while troubleshooting? Also could you private message me the IP address of your computer and the RIO? What version of the RIO driver are you using? Have you tried reinstalling MAX?
Patricia B.
Message 11 of 12
(1,946 Views)
The article in the knowledgebase is the next one: http://digital.ni.com/public.nsf/allkb/5AF28C1BCBC405FB8625773600677DCA?OpenDocument&metc=max_MAXSer...
The RIO driver is for the version of August 2011 (4.0, I think). I did not reinstall MAX, but I reinstalled several times the sw in cRio. I received assistance from NI, they told me that it's a bug that was happening with this version of the RIO when the options of HTTP were enabled. I reinstalled with these options disabled and everything is working fine by now. I appreciate your concern, and hope this issue may be solved asap.
Thanks!
Message 12 of 12
(1,939 Views)
