CRIO block diagram
HI
Can you give me the general block diagram of cRIO in serial communication (RS232)
and the detailed block diagram ( UART, FPGA)
best regards.
(5,500 Views)
If you are using the NI-987X serial modules in CRIO 901X, or greater check out the example in the NI Example finder under Hardware Input and Output>CompactRIO>Module Specific>Serial>NI-987x Serial Loopback.lvproj. If you are using Scan Engine the module can be addresses using regular VISA Serial communications as shown in the Hardware Input and Output>Serial>Basic Serial Write and Read.vi as long as you are running under RT. The VISA Serial communications apply to the built in serial ports on the CRIO systems.
Buddy Haun
Certified Trainer, Former Alliance Member, LabVIEW Champion
(5,485 Views)
hi
I mean block diagram without LabVIEW ( with visio for example)
(5,483 Views)
is it any links that can help me
(5,482 Views)
