LabVIEW RT Support for NAI PCI-76CS1
I need to use the North Atlantic PCI-76CS1 resolver card in an industrial PC that is running LabVIEW RT 7.1 code. According to NAI, there are LVRT drivers for compactPCI and PXI models 76SD1 and 76DS1. All it would take is to modify the drivers for these models to be able to use my PCI model (just a different memory map).
Where could I get the source code for these drivers that I could modify to suit my application? Does NI provide support for this type of activity?
Thank you.
(3,934 Views)
Unfortunately NI doesn't provide drivers for the boards you mentioned. Probably North Atlantic would have them. I looked for them at their web page but I only found that they are supported under LabVIEW but nothing about LabVIEW RT.
Ricardo S.
(3,916 Views)
I would like to correct  RichardoS statement. We have a LabView driver for the 76CS1. Please call or ask about LabView support from NAI. JOEA
Einstein proved by taking time in thinking about a problem he proved there is no such thing as gravitational pull. Therefore, given enough time and thought a problem can be solved. If the problem is not solved then there has not been enough thought.
(3,156 Views)
