Calculate Mean on FPGA Target
I am trying to calculate the average of an array of 50 elements; in hopes of trying to eliminate noise from an input voltage signal (NI 9215). I am using a pressure transducer, this is a 4-20mA signal which passes through a 200 Ohm resistor where I measure the voltage from this resistor. However I try to calculate the average using regular math (index the array, then sum up the array then divide by size of array)and I do not get the value expected. So is there a more efficient way of calculating an average of an array in the FPGA Target? Or better still: A way to reduce noise from an analog input in FPGA target? I am using LabVIEW 8.6.1
Thank you,
(5,862 Views)
There is a fixed point running average example on the NI Developer Zone Community:
http://decibel.ni.com/content/docs/DOC-2460
Or you could use a Butterworth Filter Express VI to eliminate noise:
http://zone.ni.com/reference/en-XX/help/371599D-01/lvfpga/fpga_butterworth_filter/
David
(5,842 Views)
bermea,
What are you measuring the pressure of?  'Noise' in pressure readings may be the result of pressure pulsations in what you are monitoring.  Some pulsations can be taken care of by installing a mechanical snubber at the pressure sensor.
(5,835 Views)
I am measuring the pressure of mineral oil, the pressure transducer is on the line that feeds in to the pressure vessel. I did try a Butterworth Filter and it did reduce most of the noise.
Thank you for the input.
(5,804 Views)
